Hi
when I create isometrics, there are no coordinates at points when lines changes the direction and not at all start or end points. And the form is not X=... Y=... (see attachm.)
I can't find a switch in the properties?!
Guido
Might be a stupid question but what are your project settings?
Isometric DWG settings\Annotations
Append coordinates and elevations - Coordinates prefixes
Are these set properly?
Hello
the settings are OK.
Please see the attachm. Two forms off coords. No coords at the elbow.
Hi Guido,
Currently the precision and the coordinate prefixes will be ignored if you use end connection annotation 'Other connected pipe lines'. The development department is already looking for this issue. Currently you have update this manually. I'm sorry for this.
Regards
Bernd
