AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISOMETRIC WEIGHT
0 REPLIES 0
Message 1 of 1
MSpadaro
348 Views, 0 Replies
ISOMETRIC WEIGHT
hi, using Plant 2015 when generating isometrics with <WEIGHT> info inserted in the BOM table of the ISO.DWT file,the sum is not represented in the right way.
The weight is given into the SPEC as data with "." [point] as decimal separator. A 3" elbow belonging to CS300 spec weights 4.47 . the isometric of just 1 elbow return 447, 2 elbows 894 and so on. The same within the pipe.
Some ideas?
0 REPLIES 0
”Boost
