Hi Yawl
I need to insert a check stamp into the iosmetric drawing template and am inserting it into the title block dwt file using the Setup Title Block within project Setup.
Unfortunately the block will work for a while but then fail and disapear from the template.
Also any modification of the template also causes the block vanish.
Anybody seen this before?
Cheers Ian W
The title block inside the .dwt file has to be called "Title Block"
Tom
Thanks for your reply
The block inside the dwt file is currently called 'Title Block'. as recomended,
but the inserted blocks still dissapear,
They are still referenced in the dwt as blocks but do not display.
Ian Whistler
Is there any chance you can upload the Iso Style you are using, with the .dwt file included? Upload it here as a zip?
Can you let us know how you solved your problem? I am having the same issue with a customers jpg on the title block. I thought it was just an Autocad anomally but I would like to fix ours also.
These are all my steps, some are probably redundant. I have a dwg that the company wants to use for a title block. I made the dwg into a dwt. Then I added a Tiff image of the company logo. I made the everything into a block called Title Block. Save. Went to project setup, isometrics, title block..searched for the location of the title block dwt. The went into the edit feature to make a BOM and drawing area. Does this help?
