I am trying to create spool drawings in Plant 3D 2012.
I have numbered the spools in the model. I have a very simple pipe line divided into 4 spools. I have set up the spool drawings to split using the setting 'use spool number from model' rather than the max dimensions. Everything seems simple and striaght forward but the spool drawings will not split as specified. I should end up with 4 sheets, 1 sheet for each spool. Instead I get 29 drawings that are not even close to the spools that I have specified. It splits the drawings at random locations and puts single components on a sheet by itself.
This would be a great part of the program if I could get it to work !!!!
has anyone else come across this problem???
what have i done wrong?? how do i fix ???
thanks
Rory
Has anyone found a fix to this problem? I am encountering the exact same issue as the OP.
Ryan
