One more thing, You can control how Isos are split up using a Break Point.
It's not the most obvious place to find it, if you go to the Iso tab, there
is a button on the menu for Isogen Info. This will bring up a dialog. Select
Break Point and place this on the pipe where you want the sheet to split.
There is a little circle that marks this spot that may be difficult to see
in shaded mode, so it might be best to do this in wireframe.
Peter Quinn (Autodesk)
"Peter Quinn"
wrote in message
news:6343442@discussion.autodesk.com...
You can control how Sheet x of y appears on the isometric by editing the
.POS file. The records you want to modify are the 702 and 703 records.
Are you looking for how to control how Isogen splits the sheets, or looking
to control what the sheet numbering scheme is?
wrote in message news:6342978@discussion.autodesk.com...
Is there any way to assign isometric sheet numbers for production
isometrics? I want to control what is going to appear on an isometric.
