I would like to ask a big favor. The default Plant 3D isometric coming out is in a single word UGLY.
Is there someone who has survived the setup process and has achieved a good result? I would be extremely happy if you share the setup. If there is any way to export would be great.
Please...
Att,
Gabriel Nogueira.
Of course the supplied Isometrics are a starting point. You would need to edit the Iso styles to suit your own border, fonts, colors etc.
Do you have a company standard drawing sheet?
Here, attached just one example of the aesthetic I think pleasing
I think the default setting might not meet your personal taste by color or etc.. But should be at least usable, which is not.
When it extracts a single isometric is a mess.
Att,
Gabriel Nogueira.
Gabriel, let me try to help you.
Please post an example of how the isometrics are comming out right now so I can see what major changes should be done in the iso settings. Are you using custom specs or defaults? Is the north of project aligned with the AutoCAD Plant 3D coordinates?
It does not help if you tell me the isometric is ugly or unreadable, let us know how it's comming out and I'll use what you have posted to achieve the best solution.
Cheers,
