Is it possible to create an isometric symbol for offset Valve.
I want two symbols one for an offset valve and the second vor an 3 way- offset valve.
Currently you have the possibiltiy to select between one of those ISO valve types:
So there is no offset valve type here. I'm not sure how you expect that the result in the isometric is, but maybe a new block, linked via SKEY from the model ad IsoSkeyAcadMap.xml which is moved by 1 unit to the top except the ports can be a working result for you:
Regards
Bernd
There are the Models for the valves and what we want to have as an isometric
Can you attach a picture of the symbols that you want?
Hi to everybody!
i am searching a symbol too for this kind of valve. 3 way or 4 way offset. (see attachment).
it does not matter how the symbol looks like, because i can edit them self.
