AutoCAD Plant 3D Forum
Isometric issue - field fit welds / make up length in cut list and dimensioning
3 REPLIES 3
milan_blom
948 Views, 3 Replies
Hi there,
It seems that when adding a field fit weld somewhere, it will be shown in the BOM, but not in the cut list. Does anyone know how to get it there?
Furthermore it would be nice if the field fit length was shown in the dimension, like with isogen. E.g. '1200+100' where +100 is the make up length.
3 REPLIES 3
in reply to: milan_blom
Anyone knows about this issue?
I am using Plant3D 2016 but still got this issue.
Anyone knows please.
Milan, If I understand what you are trying to achieve, you can go into project setup, isometric title block setup and add the shop/field property to your cut list table. Then all you have to do is select Field weld in your properties palette for the Shop/Field column to populate.
Thanks for your advise.
But I do not understand exactly your last sentence "Then all you have to do is select Field weld in your properties palette for the Shop/Field column to populate".
Please tell me more in detail please.
”Boost
