AutoCAD Plant 3D Forum
Isometric doesn't show connection? Plant 3D 2013
3 REPLIES 3
Slepe
1769 Views, 3 Replies
I have problem with connection on isometric.
Isometric doesn't show any connection to other lines. It worked at the beginning but now it doesn't any work.
I also remake few lines and they worked little while and then connections disappeared??
Tags (2)
3 REPLIES 3
Dan.Scales
in reply to: Slepe
Make sure the "Show end connection annotation on Iso" is enabled for the Iso style being used and for the specific end connection type:
I hope this helps.
Dan
Dan Scales
Slepe
in reply to: Slepe
I have checked these and there are OK.
When I make new line next to old ones it works just fine but the old ones doesn't.
I don't know if its possible to send my model to someone who can check it?
MartinStotzer
in reply to: Slepe
I have the same problem. No connections are showing, neither to sheet continuation nor drains. "Show end connection annotation on Iso" is checked.
When I change to a diffrent Iso styles it works fine but i want to use this one..
Any ideas?
”Boost
