AutoCAD Plant 3D General DIscussion
Active Contributor
Slepe
Message 1 of 4 (862 Views)
Isometric doesn't show connection? Plant 3D 2013
862 Views, 3 Replies
11-02-2012 12:09 AM
I have problem with connection on isometric.
Isometric doesn't show any connection to other lines. It worked at the beginning but now it doesn't any work.
I also remake few lines and they worked little while and then connections disappeared??
Product Support
Dan.Scales
Message 2 of 4 (796 Views)
Re: Isometric doesn't show connection? Plant 3D 2013
11-05-2012 07:39 AM in reply to: Slepe
Make sure the "Show end connection annotation on Iso" is enabled for the Iso style being used and for the specific end connection type:
I hope this helps.
Dan
Dan Scales
Active Contributor
Slepe
Message 3 of 4 (784 Views)
11-05-2012 10:08 PM in reply to: Slepe
I have checked these and there are OK.
When I make new line next to old ones it works just fine but the old ones doesn't.
I don't know if its possible to send my model to someone who can check it?
Member
MartinStotzer
Message 4 of 4 (320 Views)
11-25-2013 06:39 AM in reply to: Slepe
I have the same problem. No connections are showing, neither to sheet continuation nor drains. "Show end connection annotation on Iso" is checked.
When I change to a diffrent Iso styles it works fine but i want to use this one..
Any ideas?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
