AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric - different results from quick and production iso
1 REPLY 1
GSC_HAYA
499 Views, 1 Reply
Hello
I have a problem with the annotation for connection lines. This annotation is generated in a quick iso, when I selected some parts of the line. But there is no annotation in the production iso. Please see attachments.
(I always use the same iso style!)
What can I do or check?
Thanks Guido
WIN7, P3D 2014
Plant3D 2022 German
WIN10 Pro
1 REPLY 1
GSC_HAYA
in reply to: GSC_HAYA
Hello
I found the errors. I've divided the line, created the iso and got error messages that were not shown before?!
There were two parts with problems
FEHLER  - Ungültige Komponente in Modell - PIPE: Name = S1, Punkt = (94148,0969,10742,212,-1000), Größe = 50,00, Verz. = (-0,999999999999551,9,47521865816664E-07,0), Ende = ; Name = S2, Punkt = (95520,0969,10742,2107,-1000), Größe = 50,00, Verz. = (0,999999999999551,-9,47521865816664E-07,0), Ende =
FEHLER  - Ungültige Komponente in Modell - TEE: Name = S1, Punkt = (95648,0969,10742,2107,-1000), Größe = 50,00, Verz. = (1,0,0), Ende = BW; Name = S2, Punkt = (95520,0969,10742,2107,-1000), Größe = 50,00, Verz. = (-1,0,0), Ende = BW
WARNUNG - Im Modell der Leitungsnummer KO00 R 7002.50-100a-2 wurden einzelne Komponenten gefunden.
After deleting these parts and rebuilding everything is ok.
G
Plant3D 2022 German
WIN10 Pro
”Boost
