AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric Cut Back elbow in BOM
8 REPLIES 8
Message 1 of 9
samans
1662 Views, 8 Replies
Hi
I was wondering how can show the cut back elbow in isometric BOM once I generate Isometric?
Thanks, Saman
8 REPLIES 8
Message 2 of 9
PeterQuinn
in reply to: samans
It doesn't just include the cut back angle?
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Message 3 of 9
dave.wolfe
in reply to: PeterQuinn
In isometric title block setup, go to Table Setup, and then the settings tab.  Check Show cutback elbows as separate line items.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 4 of 9
DGRL
in reply to: dave.wolfe
@dave.wolfe
I know this is an old thread but do you know how to round the number off?
right now i have a cutback elbow shown in BOM As 59.999 degrees
I want to round this off to 60
Hope you know
Kind regards
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Message 5 of 9
Stumble
in reply to: DGRL
Hi Dave, did you ever get an answer on this?  I would like to round BOM cutback description to 2 decimal places.
Bryan Appleton
Message 6 of 9
Vasu27
in reply to: Stumble
@Stumble,
You can try changing the precision in Isoconfig.xml, in the line "<Precision Name="CutbackAngle" Precision="2" />".
Or, you can simply change the value in the property 'Çutback Angle', through Data manager.
Vasu
Message 7 of 9
DGRL
in reply to: Vasu27
@Vasu27
This line does not seems to work.
I configured this line to be 2 digits and still get more.
Kind Regards
Message 8 of 9
Vasu27
in reply to: DGRL
@DGRL,
You will actually find that line 3 times in the config file. Have you tried changing them all?
Any way, the option I prefer is to change the value of the property 'Çutback Angle' through Data Manager. Again, changing it through Properties window doesn't seem to work.
Vasu
Message 9 of 9
DGRL
in reply to: Vasu27
@Vasu27
In our config file this line only comes 1 time.
it might be "corrupt" i guess
Kind Regards
”Boost
