Hi
I was wondering how can show the cut back elbow in isometric BOM once I generate Isometric?
Thanks, Saman
Solved by dave.wolfe. Go to Solution.
It doesn't just include the cut back angle?
In isometric title block setup, go to Table Setup, and then the settings tab. Check Show cutback elbows as separate line items.
I know this is an old thread but do you know how to round the number off?
right now i have a cutback elbow shown in BOM As 59.999 degrees
I want to round this off to 60
Hope you know
Kind regards
Hi Dave, did you ever get an answer on this? I would like to round BOM cutback description to 2 decimal places.
You will actually find that line 3 times in the config file. Have you tried changing them all?
Any way, the option I prefer is to change the value of the property 'Çutback Angle' through Data Manager. Again, changing it through Properties window doesn't seem to work.
Vasu
