AutoCAD Plant 3D Forum
Isometric Customization
8 REPLIES 8
Message 1 of 9
6890 Views, 8 Replies
I have read all the post on this and other post but still have a question.  I want to use a property that the line contains to put in front or back of the line number when creating the isometric.  For instance, I made an area property and assigned each line number with an area.  How can I program the Isoconfig.xml to look for that property?
Thank you,
Robert
Edited by
Discussion_Admin
8 REPLIES 8
Message 2 of 9
jason.drew
Are you using Plant 3D 2012 or 2011?
In 2012 it's fairly simple to change the default Iso line tag to use the actual line group tag from the model. Open IsoConfig.xml in Notepad or MS XML Notepad 2007 and search for "LineNumberScheme" the second entry that is found should take you to a line similar to this:
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
Change Format="{0}-{1}" to Format="{0}" as highlighed above.
Jason Drew
Designated Support Specialist
Message 3 of 9
in reply to: jason.drew
We are using P3D 2012.
I don't think I explained this correctly. We are trying to incorporate an area designation seperate from the line #.  We added a selection list property called "Area" in "P3d Line Group" that is a selectable property.  Once the line has been assigned a line #, someone will go back to the change properties dialogue box and select what area the pipe is in.  We are doing this because we do not want the line # Tag in the model to contain the Area.
We want to take that "Area" property and incorporate it with the line # and make that our Isometric Drawing Name.
Is this possible?
Thanks again,
Robert
Message 4 of 9
TomislavGolubovic
When you create the Isometric, does that field appear in the PCF file it also creates? It'll be near the top of the file.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 5 of 9
jason.drew
Hi Robert,
Let me check into this and I will let you know if it's possible or not.
Thank you,
Jason Drew
Message 6 of 9
jason.drew
Hi Robert,
I checked with the software development team and they said it is currently not possible to append the area number into the Iso drawing name.
I am currently looking into a workaround by using the P3d line Group area number property. You can place this as an attribute on your Iso title block and at that point it writes to the PCF file. If we can get the area number attribute from the PCF to append with the line number tag (inside IsoConfig.xml - LineNumberScheme) then it should be possible.
I will do some additional research and let you know what I find.
Thank you,
Jason Drew
Message 7 of 9
jason.drew
Hi Robert,
I finally a solution for adding the area number behind the line number on the Isometric drawings.
This requires some configuration inside the IsoConfig.xml and the Iso.atr files for your Isometric style.
These files can be found in the sub-folder of Isometric in your project, for example:
C:\Projects\Project Name\Isometric\Final_A3\IsoConfig.xml
C:\Projects\Project Name\Isometric\Final_A3\Iso.atr
In testing, I created a new P3dLineGroup property in Project Setup and called it "AreaNumber"
I modified the Iso.atr using Windows Notepad to include the following (be sure to turn off word wrap option in Notepad):
ATTRIBUTES
Attribute1 P3dLineGroup.Service
Attribute2 P3dLineGroup.NominalSpec
Attribute3 P3dLineGroup.InsulationThickness
Attribute4 P3dLineGroup.InsulationSpec
Attribute5 Drawing.Unit
Attribute6 General.Project_Number
Attribute7 P3dLineGroup.LineNumber
Attribute8 General.Project_Name
Attribute9 General.Project_Description
Attribute10 P3dLineGroup.AreaNumber
BOM-ATTRIBUTES
EngineeringItems.Schedule
EngineeringItems.PressureClass
EngineeringItems.Material
EngineeringItems.PartSizeLongDesc
Next, I opened IsoConfig.xml and searched for "LineNumberScheme" (click "Find Next" button twice and you should be at the proper location in the file)
I made the following changes for the default line number annotation scheme:
Default configuration
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
Modified configuration
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{1}-{0}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE ATTRIBUTE10" ComponentFormat="{0}-{1}" LineFormat="{0}-{1}" />
Basically switching the formar around so the Line Fields show up after the Component Fields and then adding the additional entry for the LineFormat so it would include the new ATTRIBUTE10.
One thing to note; if you do not type in a value for the Area Number in the Process Line properties, nothing will show up for the line number in the Iso drawing. You can enter a "." or any character as a placeholder so the line number will still generate.
Jason Drew
Message 8 of 9
I have the similiar question. I tried different ways, but didn't find the answer. May be someone will help me.
I want to have in a iso line tag two component properties: MatchingPipeOd and WallThickness.
 I wrote it to the isoconfig.xml
LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="MatchingPipeOd WallThickness" LineFields="Attribute7 Attribute1" ComponentFormat="{0}х{1}" LineFormat="{0}-{1}" />
<!-- Property breaker annotation scheme -->
But it doesn't work. Then I realised that I should add it into the table in iso.dwt like this http://clip2net.com/s/2SuDL
It helps http://clip2net.com/s/2SuNZ , but I don't want this parametrs in my tables. If I go again in iso.dwt all my settings dissapeared http://clip2net.com/s/2SuPx
Why does it happend and it seams that it has properties from another iso.dwt.
Thank you for help
Best regards
Marina
Message 9 of 9
sbbhojane
dear Sir,
I made change as you said. after changing this setting when i creat isometric it is not taking any line no.it is showing as per attached image.
please reply
Regards
Sandesh
”Boost
