I have a couple Isos that won't run and keep throwing errors. Below I've attached the log files. Anyone have any ideas? Your help would be greatly appreciated.
Solved by TRdesigner82. Go to Solution.
The logs point to issues in the 3D pipe model. Start with troubleshooting the 3D piping and parts themselves. Is it all out-of-the-box (OOTB) components? Or lots of customization there? Maybe include some screenshots of the pipeline your trying to get an Iso on and the corresponding properties.
What happens if you try a different Iso style? An OOTB Iso style?
Thanks Martin. I messed around with these line a bit more and ended up being able to get them to run. They all had sockolets placed on the weld line of weldneck flanges, reducers, ect... I went and added a couple inches of pipe and moved the sockolets to the pipe and they ran. I'm not sure how they ended up on the weld lines but Plant didn't like it.
I believe I had a similar issue before. Two small sockolets back to back on a piece of pipe. The iso would not run. If I moved one of the sockolets 0.001", the iso would work.
Usually when I have iso generation issues, I'll quick iso small portions of the line until it breaks. Then start investigating. It's usually some fitting that needs to be redone for some reason.
