AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric Coordinates in pipeline continuation and sheet number call
7 REPLIES 7
Message 1 of 8
feschaurich
1496 Views, 7 Replies
Is there any way to set the coordinates in pipeline continuation to format N S EL? And how can I make to appear the isometric sheet number next to the called line tag number (See attached file).
Fernando
7 REPLIES 7
Message 2 of 8
Indesh
in reply to: feschaurich
Go to project set-up - Isomoetric DWG setting-Annotations...
in the end connection annotations, you have Iso sheet continuation (to) and Iso sheet continuation (from)
select one by one and type the what you want to appear in the "connection text prefix"
don't forget to tick "show end connection annotation on iso.
also tick the property names.
"append coordinates and elevation
and down you can name your coordinate prefixes.
Message 3 of 8
paragnewe
in reply to: Indesh
hello friend,
what attribute we need to set for sheet number display at connection?
i tried SH# but cant get any lead in that.
-Regards
Prag
Message 4 of 8
Indesh
in reply to: paragnewe
Dear Friend,
Where actually your sheets numbers don't appear is it on the iso dwg or the title block(frame)
If on the iso dwg ...you should follow the steps mentionned before.
if on the title block then refer as follows.
go th title block setup in project setup. then title block attributes... a window will pop "insert title block attributes"
on the tab add attibutes, in attribute category select all.then try to find "sheet" and click on map attribute.
on the map attribute window, on the block attribute side, find TL  and SH.map both of them total count and sheet on the plant 3d attributes side respectively.
it should work.
BUT THE FIRST THING DO CHECK YOUR ISO STYLE.WHETHER IT IS A3 FINAL OR CHECK A3 ETC.
.....IT MAY COMES THAT YOU HAVE MADE THE SETTINGS ON A3 FINAL AND GENERATING ISOS ON CHECK A3, IT WONT WORK....
DONT FORGET TO KUDOS
Message 5 of 8
paragnewe
in reply to: Indesh
I want like this..
now  drawing number is coming and i required Sheet number.
in title block,
i have already set all attributes..
-Regards
Prag
Message 6 of 8
Message 7 of 8
paragnewe
thanks Daniel
what about continuation part?
-Regards
Prag
Message 8 of 8
paragnewe
any clue friends?
-Regards
Prag
”Boost
