Isometric bubbles for pipe are orientated different from the rest of the items in BOM. How do you fix this? SEE ATTACHED IMAGE
Solved by jabowabo. Go to Solution.
This is driven by *this line of code in the isoconfig.xml file:
<ComponentScheme Name="PartNumberAligned" AnnotationStyle="Name="Circle" Tag="XX" Alignment="FlatAligned" LeaderStyle="NoLeader" Filter="Pipe" Fields="PartNumber" />
Change it to this (here we're just adding 'Enabled="false"):
<ComponentScheme Name="PartNumberAligned" AnnotationStyle="Name="Circle" Enabled="false" Tag="XX" Alignment="FlatAligned" LeaderStyle="AlwaysNonArrowed" Filter="Pipe" Fields="PartNumber" />
Then add this line:
<ComponentScheme Name="PartNumberPipe" AnnotationStyle="Name="Circle" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="Pipe" Fields="PartNumber" />
*You're code may not look exactly like this but should be pretty close,
Thanks. It worked. By following those steps, it has also fixed my issue of drains coming in as rectangles!
