AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric bubbles for pipe are coming in WRONG!!!
2 REPLIES 2
scarughi
781 Views, 2 Replies
Isometric bubbles for pipe are orientated different from the rest of the items in BOM. How do you fix this? SEE ATTACHED IMAGE
scarughi
2 REPLIES 2
jabowabo
in reply to: scarughi
This is driven by *this line of code in the isoconfig.xml file:
<ComponentScheme Name="PartNumberAligned" AnnotationStyle="Name="Circle" Tag="XX" Alignment="FlatAligned" LeaderStyle="NoLeader" Filter="Pipe" Fields="PartNumber" />
 Change it to this (here we're just adding 'Enabled="false"):
<ComponentScheme Name="PartNumberAligned" AnnotationStyle="Name="Circle" Enabled="false" Tag="XX" Alignment="FlatAligned" LeaderStyle="AlwaysNonArrowed" Filter="Pipe" Fields="PartNumber" />
 Then add this line:
<ComponentScheme Name="PartNumberPipe" AnnotationStyle="Name="Circle" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="Pipe" Fields="PartNumber" />
 *You're code may not look exactly like this but should be pretty close,
scarughi
in reply to: jabowabo
Thanks. It worked. By following those steps, it has also fixed my issue of drains coming in as rectangles!
scarughi
”Boost
