AutoCAD Plant 3D Forum
Isometric BOM-exact length of pipe
5 REPLIES 5
neonade
1936 Views, 5 Replies
Guys,
Is there a way i can change the default quantity (total length) of pipe on the BOM of the isometric, changing it from Meter to Millimeter.
5 REPLIES 5
alain.mallette
in reply to: neonade
i don't have the answer for your question but me i have one for you! How did you seperate your pipe size in the BOM
I always have label #1 for every pipe nominal size and grouped in item #1 in BOM. I tried different description and it always group it in item #1 with 2 description side by side....
HELP ME PLEASE!!! Smiley Happy
Tags (3)
ybogdanov
in reply to: alain.mallette
Open IsoConfig.xml of your style format, and search the following lines, change scale in the las line from 0,001 to 1:
Precision: (string); Options include Precision<N> where N is in the range of 1 to 9.
<!-- 'Prefix': (string); The prefix that will be added to the formatted measurement. -->
<!-- 'Suffix': (string); The suffix that will be appended to the formatted measurement. -->
<!-- 'Scale': (double); The scale factor that will apply to the measurement. e.g. 0.001. -->
<!-- 'Decimal': (string); The decimal separator. e.g. '.', ',' or ' '. -->
<Style Name="Imperial" UnitFormat="Architectural" Precision="Precision5" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="ImperialSize" UnitFormat="Fractional" Precision="Precision5" Prefix="" Suffix="&quot;" Scale="1" Decimal="." />
<Style Name="ImperialPipeLength" UnitFormat="Architectural" Precision="Precision5" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="ImperialPipeLengthAlt" UnitFormat="Architectural" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="Metric" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="MetricSize" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="MetricPipeLength" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="mm" Scale="1" Decimal="." />
<Style Name="MetricPipeLengthAlt" UnitFormat="Decimal" Precision="Precision2" Prefix="" Suffix="M" Scale="0.001" Decimal="." />
</Styles>
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
DGRL
in reply to: ybogdanov
Hi All members and Autodesk.
Above is not correct solution
Where is the switch to control this?
I don't want to edit the config file this way.
I juist want to switch between,
Some of my clients has M and MM in the same project.
And where can I change the precision of digits behind the dot?
Now there is 1 digit behind the dot and for MM units that's weird.
I cant show an size of 850.6 MM this should be 851 MM
where can I change this?
Cam someone point me to the switch responsible for the 2 lines above?
Kind regards
If this was of any help please kudo and/or Accept as Solution
Kind Regards
DGRL
in reply to: DGRL
UPDATE,
I just found the precision switch ( the digit behind the comma is gone. )
Kind Regards
DGRL
in reply to: DGRL
Found the fix ( it was written inside the isoconfig.xml
 <!-- The alternate dimension style used for formatting pipe length measurements -->
    <!-- Set UseAlternateUnitsStyle='true' in the <AggregatedList> section to enable -->
    <!-- alternate pipe length units for a data list. -->
Out of the box this value is TRUE.
Changed it on 3 different places and fixed
Have mm size of piping on BOM now
Hope this helps others also to get what they want
HAPPY CODING Everybody
Kind Regards
”Boost
