AutoCAD Plant 3D General DIscussion
Valued Contributor
4 Kudos
Post 1 of 3
Isometric BOM-exact length of pipe
376 Views, 2 Replies
11-16-2011 06:36 PM
Guys,
Is there a way i can change the default quantity (total length) of pipe on the BOM of the isometric, changing it from Meter to Millimeter.
Open IsoConfig.xml of your style format, and search the following lines, change scale in the las line from 0,001 to 1:
Precision: (string); Options include Precision<N> where N is in the range of 1 to 9.
<!-- 'Prefix': (string); The prefix that will be added to the formatted measurement. -->
<!-- 'Suffix': (string); The suffix that will be appended to the formatted measurement. -->
<!-- 'Scale': (double); The scale factor that will apply to the measurement. e.g. 0.001. -->
<!-- 'Decimal': (string); The decimal separator. e.g. '.', ',' or ' '. -->
<Style Name="Imperial" UnitFormat="Architectural" Precision="Precision5" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="ImperialSize" UnitFormat="Fractional" Precision="Precision5" Prefix="" Suffix="&quot;" Scale="1" Decimal="." />
<Style Name="ImperialPipeLength" UnitFormat="Architectural" Precision="Precision5" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="ImperialPipeLengthAlt" UnitFormat="Architectural" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="Metric" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="MetricSize" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
<Style Name="MetricPipeLength" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="mm" Scale="1" Decimal="." />
<Style Name="MetricPipeLengthAlt" UnitFormat="Decimal" Precision="Precision2" Prefix="" Suffix="M" Scale="0.001" Decimal="." />
</Styles>
New Member
0 Kudos
Post 2 of 3
Re: Isometric BOM-exact length of pipe
04-02-2013 12:37 PM in reply to: neonade
i don't have the answer for your question but me i have one for you! How did you seperate your pipe size in the BOM
I always have label #1 for every pipe nominal size and grouped in item #1 in BOM. I tried different description and it always group it in item #1 with 2 description side by side....
HELP ME PLEASE!!! :smileyhappy:
Valued Mentor
80 Kudos
Post 3 of 3
04-02-2013 03:29 PM in reply to: alain.mallette
</Styles>
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
