I am having a problem when I try to define the table for BOM in isometric setup. I get this unhandled exception error message and the BOM doesn't show up.
The same errors occur on several machines. I have read that it is an issue with NVidia video cards. All the machines have this brand card. I have heard that using a Autodesk generic driver could help.
Anyone else have this issue???
ERROR MESSAGE
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.ArgumentNullException: Value cannot be null.
at Autodesk.ProcessPower.Iso.Generator.TableGenerator .GenerateTableTemplate(Database db, ObjectId rectId, IsoConfigDefinition config, TableType tt)
at Autodesk.ProcessPower.PnP3dIsoUI.ISOUIUtils.Genera teTables(Database db, TableType type, TableArea area, TableDirection& direction)
at Autodesk.ProcessPower.PnP3dIsoUI.Commands.TableCmd Run()
at Autodesk.ProcessPower.PnP3dIsoUI.Commands.PlantIso PlaceTable()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker (MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker WithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk .Invoke()
