Hi Everyone
I am generating isometric drawing for our current project but I noticed annotation for some of the branches is not shown up in Isometric.. it happens not in all branches just some of them! Any idea why this one happening. At the begging I was thinking that happen because of our plant 3D 2013 version. But once we upgraded to 2015 still same issue..
Please see attached image.
Thanks, Saman
Hi Samans,
Not sure if the issue has been resolved yet, I have noticed this as well on my projects. It seems to occur with the P3Dconnector, just remove it and "connect component to adjacent", regen iso and then should be fixed.
This works for me.
Good luck
Hi Steve
Actually I tried many times. I deleted and re-connected the branch again to make sure line number is correct. (branch has different line number). I checked connection point as well (weld point). I am not sure what is issue? it seems to me plant 3d just recognize one type of branch connection creation method.
Thanks, Saman
Are the missing connections in the PCF file?
If they are, I'd like to get an example PCF that shows the problem.
We've fixed some issues in this area for 2015 and some additional ones for an upcoming release. If I can get a pcf file that shows the problem, I'll have someone test it to see if we've fixed it already.
Hi Peter ;
Thanks for your replay. I don't know how to check if any disconnect in PCF file or not. Can you please show me how can I send you PCF file? I tried to send you with this post through attachment but for some reason I get this message "The contents of the attachment doesn't match its file type" .and don't let me attach file
Thanks, Saman
You can email me the PCF and I'll try it.
peter.quinn@autodesk.com
Using the default ANSI-C style in 2015, the annotation appears. There must be something else going on.
same problem i am facing if any body found any solution please share with me.
