AutoCAD Plant 3D Forum
Isometric Angle 3D Box
4 REPLIES 4
Ahmed1081975
625 Views, 4 Replies
Hi Autodesk Support,
My iso Settings is show 3d Box for the any angle pipe routing but it show only iso rectangle, I thought this because it depend the directions but if you looking the settings suppose came as box as per my iso settings
Ahmed Helal
4 REPLIES 4
Dan.Scales
in reply to: Ahmed1081975
Hi Ahmed,
To get the 3D Box in the isometric the pipe needs to be sloped in both the horizontal and vertical plane.
The screen shot below illustrates this:
I hope this helps.
Dan
Dan Scales
Ahmed1081975
in reply to: Dan.Scales
Thanks Dan for Your Reply,
Possible to show as per the attached file ?
Ahmed Helal
Dan.Scales
Hi Ahmed,
It is not possible to get the 3D Box for a 2D skewed pipe.
The nearest you can get is a 2D box with no hatch:
I will log a wish list with our developers for the setup you are looking for.
Dan
Dan Scales
Ahmed1081975
Thanks Dan
Regards
Ahmed Helal
”Boost
