AutoCAD Plant 3D Forum
Isogen Spool Number
1 REPLY 1
sreid13
1657 Views, 1 Reply
Isogen Spool Number
Hi, I'm able to create a spool number with a line reference and a spool number as shown in the attached pic. But i want to be able to have 999-6 instead of 9996. Does anyone know what setting i have to change to achieve this?
Also does anyone know how to get rid of the spool tags on valves and other things that aren't pipe spools?
Scott
1 REPLY 1
in reply to: sreid13
Scott,
I don't know how to do the first part.
To not have spool numbers show up on the valves, set the valve's shop/field
property to Field. I think you can do this in your spec, so you won't have
to do it for each instance of a valve in your model.
Peter Quinn (Autodesk)
wrote in message news:6351849@discussion.autodesk.com...
this?
Scott
”Boost
