AutoCAD Plant 3D Forum
Isogen Spec Breaks
11 REPLIES 11
Message 1 of 12
cad.westie
2919 Views, 11 Replies
Isogen Spec Breaks
Does anyone know how to suppress the isogen spec breaks ? I assume this can be done by editing the .opl file, but unsure of which switch number this is.
11 REPLIES 11
Message 2 of 12
awerning
in reply to: cad.westie
The only switch in the .opl that has to do with spec breaks is #114 and it is only for single sided or double sided spec breaks.  I would suspect that if you have any chance it will be adjusting the alternate text file #232.  I believe that there is functionality built into isogen that says that if you blank out the value ("SPEC") for #232 that it will suppress the call out altogether.  I know that this works for other things in the atext file so hopefully it will work here.  I haven't tried it though, so let us know how it works!
Message 3 of 12
cad.westie
Thanks for the solution, adding 232 as blank to the alternative text file worked.
Message 4 of 12
MOLGRAND
in reply to: awerning
Where can you find the list of "AText identification numbers" - is there a manual covering this topic some where or a file within P3D?
Gary
Message 5 of 12
cad.westie
in reply to: MOLGRAND
Hope this is what you are after.
Message 6 of 12
MOLGRAND
Message 7 of 12
So...how to turn them off in 2012???
Message 8 of 12
cad.westie
The following worked for me : Edit the isoconfig.xml file and search for "specbreak" then rem out the line as shown below by adding !-- :
<!--<AnnotationStyle Name="SpecBreak" TextStyle="AdskIsoAnnotation" BlockName="AnnoSpecBreaker" /> -->
Message 9 of 12
thanks
I just renamed the SpecBreaker block in the symbols file.  did the job
I was looking for the 'enabled' true setting to change to false but the switch doesnt seem to be coded
Message 10 of 12
Arun_Kumar_K
Can anyone ellobrate "What is Isogen spec breaker", as i don't understand, ll be useful to me.
Message 11 of 12
in reply to: Arun_Kumar_K
as you move along a pipeline, sometimes the spec will change for the pipe
at these points on the ISO, a flag is raised (similar to a battery limit tag)
that way it is clear to the piper or spooler that a different spec is in play.
Message 12 of 12
Arun_Kumar_K
got it, thanks.
”Boost
