AutoCAD Plant 3D General DIscussion
Active Contributor
CaveManCode
Message 1 of 7 (2,088 Views)
Isogen Line Number font and height
2088 Views, 6 Replies
09-25-2012 12:16 AM
Hi All
How would one change the height for the line number and font
In the iso themes there are settings for annotation text and symbol scale, as well as one can change the fonts and text heights in the isometric symbol blocks, But this does not include the Line Number that gets inserted? where can one change this?
Active Contributor
CaveManCode
Message 2 of 7 (2,065 Views)
Re: Isogen Line Number font and height
09-26-2012 12:30 AM in reply to: CaveManCode
From the Screen Shot below
On the Isogen the LineNumber gets  auto inserted
We need the Auto Configuration to insert this text at Size 2.5mm
Where does one configure this?
Previous comments which i havd recieved indicated that the configuration in the theme controls this as illustrated below, but this is not the case
To configure the Line Number style this is done in the Isoconfig.xml but there it also does not have an immediate option to set the text height?
From xml file: <LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
any assistance welcome
Product Support
jason.drew
Message 3 of 7 (1,953 Views)
01-08-2013 09:00 AM in reply to: CaveManCode
I have recorded a video outlining the process of creating a custom line number tag annoation style:
Iso Line Number Annotation Style
It requires adding a new text style for the iso themes in title block setup and also making a modification to the IsoConfig.xml to assign the custom text style to only the line number tag annoation.
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Active Contributor
CaveManCode
Message 4 of 7 (1,943 Views)
01-08-2013 09:25 PM in reply to: jason.drew
Hi Jason
Much appreciate your assistance
The link which you have sent is not functional? Not to sure says cant find Http page?
If you can check this for me would really appreciate
Thanks in advance
Regards
Richard
Product Support
jason.drew
Message 5 of 7 (1,937 Views)
01-08-2013 09:30 PM in reply to: CaveManCode
Hi Richard,
My apologies. I have corrected the error in the HTML link and it should work now.
Thank you,
Jason Drew
Product Support
Active Contributor
CaveManCode
Message 6 of 7 (1,931 Views)
01-08-2013 09:43 PM in reply to: CaveManCode
Jason . . .
She's working!!
Thanks for the assistance, have a good day
In Appreciation
Richard
Active Contributor
CaveManCode
Message 7 of 7 (1,758 Views)
04-18-2013 06:23 AM in reply to: CaveManCode
Good Day
The previous method only worked if the line was within the slope limits of producing the iso.
If the pipe is sloped then it produces the line number in an iso view and the size of the text changes again?
the font style and all is correct . . .
do you think that there may be more parameters in the xml file that will have to get configured . . .
or does this look like a general bug?
Regards
Richard
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
