AutoCAD Plant 3D General DIscussion
Member
ludwigman
Message 1 of 4 (629 Views)
Isogen Bill of Materials help??
629 Views, 3 Replies
04-23-2010 08:21 AM
I am trying to create a custom BOM to show on my iso.
The picture above shows how I am trying to set this up.
FYI, I have created a spec that was used to create the piping that the iso will be generated from. I have manually added information to the Long Description(size), Material and schedule fields within the spec editor. These fields are represented in the pic of the BOM setup I have provided. You can see that the fields have been checked.
The problem is that when I uncheck- "Use type 1 bill of materials (BOM)" I don't get any BOM on the iso and it splits a basic run of pipe into several iso dwg's. With the option checked I get 1 iso and the default BOM which I do not want.
Do I need to manipulate the OPL, POS and MLD files to get this done?
What am I doing wrong? Edited by: ludwigman on Apr 23, 2010 3:42 PM
Employee
sivapd
Message 2 of 4 (627 Views)
Re: Isogen Bill of Materials help??
04-23-2010 07:04 PM in reply to: ludwigman
Inside the OPL file switch 23 control the BOM style. A value of 300 represents a user defined BOM style and requires MLD file to control the BOM. The MLD file has the BOM columns and their position coordinates. Please take a look at the Final.OPL and Final.MLD when a new project is created as an example. Make sure that the coordinates defined in the MLD are inside the overall drawing plot area. If it is goes outside, I guess that is when it splits the iso into multiple sheets.
Thanks, Siva (Autodesk)
Siva Thankappan
Technical Sales, Plant Solutions, Asia Pacific
Autodesk Singapore
Active Contributor
PHammink8001
Message 3 of 4 (628 Views)
04-26-2010 12:14 AM in reply to: ludwigman
Use notepad to change your OPL and MLD file. Don't use the settings in P3D, it does wierd things sometimes.
Peter Hammink
Primat Project Service BV
Employee
ausdag
Message 4 of 4 (629 Views)
04-26-2010 04:50 AM in reply to: ludwigman
Hi Ludwig
A MTO can be build up in several ways and it can be a little confused to understand all the setting you can select to do this.
To help you with this, I need a example of your typical Iso with a complete BOM list. I can then guide you to what files etc. through your example.
Dag Austrheim
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
