AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isogen 0,0,0
5 REPLIES 5
ludwigman
609 Views, 5 Replies
Isogen 0,0,0
It is my understanding that when an iso is created it automatically uses 0,0,0 as the origin. My question is if I can manually define the point of origin? For example if I wanted to create an iso based on a specific point in a building like a column. I do not want the column to be at 0,0,0 because the building is placed in the DWG at a real distance from 0,0,0. I basically want to pick a point inside the building and have the iso recognize it as a start point other than the actual 0,0,0 of the DWG itself.
5 REPLIES 5
in reply to: ludwigman
Ludwigman,
Yes, the origin for isometrics is 0,0,0. I don't know of any way to relocate
the iso short of moving the entire project.
Peter Quinn (Autodesk)
wrote in message news:6346290@discussion.autodesk.com...
DJPiper
Before you hit Ok for iso extraction in CADWorx, there is an option there for a user to input X,Y,Z coordinates
How About doing the same thing for AP3D?
Richard,
We could define a plant origin, similar to what Cadworx does. However, I
think Isogen's reference dimension feature, where you can dimension to a
column line, equipment, building, etc would probably be the best solution.
We don't have either now, but it's something to consider for future
versions.
wrote in message news:6349239@discussion.autodesk.com...
chad70811
Yes we definitely need the reference point feature for isogen added to the program. It is a feature I will miss from my last 3d piping program (ACplant).
PHammink8001
I would prefer a reference dimension to a collum, pump, etc. The guy at site who has to install the line uses the reference dimension and not the plant zero point.
Peter Hammink
Primat Project Service BV
”Boost
