AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isoconfig.xml and IsoSymbolStyles.dwg files from 2012 into 2013
3 REPLIES 3
PatrickByrne
438 Views, 3 Replies
I am setting up a project in Plant 3D 2012. When we upgrade to 2013 is there anything I need to do to migrate the files Isoconfig.xml and IsoSymbolStyles.dwg from 2012 into 2013 or can I just copy them into the new Isometric folder.
3 REPLIES 3
Rich.O.3d
in reply to: PatrickByrne
Pretty sure that you just open the 2012 project in 2013, it will ask you if youwant to migrate it.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Hi Patrick,
Rich is correct. If you think this xml files are not added, you can add them to add files in the migration dialog and it will back up and migrate it as well.
Hope that helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Thanks, I will try again later.
I had a problem with the Isometric symbol for the Stub ends reversing in 2013 but worked okay in 2012.
”Boost
