AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
iso valve operator direction
3 REPLIES 3
1091 Views, 3 Replies
Hi
how can I change the valve operator direction e.g. from UP to DOWN and eventually rewrite quotes "UP" and "DOWN" in iso drawing (e.g. "OPERATOR UP") to another language?
Thank you in advance.
3 REPLIES 3
h_eger
  <ValveOperatorDirectionAliasMappings>
    <DirectionAliasMapping UP="UP"/>
    <DirectionAliasMapping DOWN="DOWN"/>
    <DirectionAliasMapping NORTH="NORTH"/>
    <DirectionAliasMapping SOUTH="SOUTH"/>
    <DirectionAliasMapping EAST="EAST"/>
    <DirectionAliasMapping WEST="WEST"/>
  </ValveOperatorDirectionAliasMappings>
see in the File "%:\<<Project>>\Isometric\BoltSizeMappings.xml"
R.
Hartmut
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
thanks very much hartmut! 😉
wbdc.autodesk
Within the boltsizemappings.xml we are editing this variable for all iso templates.
Within one project we have iso templates to work with locacl operator coordinates (x,y,z) and global (fwd, stb, el).
Could you please provide a solution how to use two settings in parallel? Maybe some if command?
Currently we need to turn one option on and second off.
<DirectionAliasMapping NORTH="PORT"/>
<DirectionAliasMapping SOUTH="STB"/>
<DirectionAliasMapping EAST="FWD"/>
<DirectionAliasMapping WEST="AFT"/>
<DirectionAliasMapping NORTH="+Y DIRECTION"/>
<DirectionAliasMapping SOUTH="-Y DIRECTION"/>
<DirectionAliasMapping EAST="+X DIRECTION"/>
<DirectionAliasMapping WEST="-X DIRECTION"/> -->
”Boost
