Show only
Search instead for
ISO Title Block - Output Date-Time, Output by, List of Specs
Looking to add the following to ISO Title Block
Output date WITH time
Output by (Windows Username)
List of specs on given sheet
I played around with output date, and from P3D Attributes you can easily get the output date, but not the time. If you use regular MTEXT fields you can also get generic properties like LastSaved, DateCreate, etc. However these will then show the ISO template's creation date as opposed to the ISO production date.
Playing around with Author doesn't work unless someone actually sets the author field in Drawing properties for regular AutoCAD stuff. The regular AutoCAD field LastSavedBy doesn't work well in case the drawing changes hands and things get modified. P3D doesn't seem to have an "author" field for ISO. It does have one for P&ID, 3D Model and Orthos since they are "PNPID" files.
By this I am looking to create a list of specs for a given sheet, as an output. In say a couple of unique rows. For example our line number defines the Nominal Spec, or expected spec. What I want is a list of the specs that come straight from the 3D Model for this sheet. Example being: Nominal Spec shows SpecA, and this custom field shows SpecA, SpecB, PlaceHolderMetric. Immediately our checker is aware that the designer has used the wrong specs.
