AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISO Template
8 REPLIES 8
Message 1 of 9
arjan.gorinsekéman-engineering.be
834 Views, 8 Replies
ISO Template
Is there a guide for making a custom template?
How to change the north arrow,
Change text height of the dimension,
custom partlist, ....
If anyone has a good template maybe you can share it?
8 REPLIES 8
Message 2 of 9
I am not sure if there is an explicit document that details how to make a custom template. The Plant3d help documentation on Iso should help you out. You will need to go through the project setup in Plant3D to set the north arrow.
In brief, north arrow can be changed using the drawing setup UI. Text height can be changed by using switches 4 and 27 in the opl file. There is no UI exposed currently to set these two switches.
Switch 4 to control the text size of Dimensions, Coordinates, Message Text, etc.
Switch 27 to control the material list text.
As for a template, maybe someone has it.
HTH.
Ratti.
Autodesk.
Autodesk, Inc.
Message 3 of 9
Thanks this is working.
Is there an explanation for all the switch number?
Message 4 of 9
Hi Arjan
Unfortunately, we do not have any good whitepaper on this.
A template can be created two way, through the 3D Plant Isogen settings, or Alias OPT editor.
I do have a custom template with custom MTO etc. See attachment.
Change the path in the FLS file to yours path.
You can use the Alias editor tool for Isogen configuration. Just search the internet for Alias Isogen editor, and you will find several document for download.
Dag Austrheim
Message 5 of 9
then you send me a link where i can download alias isogen editor?
Message 6 of 9
Hi
This has to be sent by your reseller. If you can send me the name of your reseller, then I can ask him to send it to you.
R.
Dag Austrheim
Message 7 of 9
Hi
R.
Dag Austrheim
Message 8 of 9
Reseller is CADAC
http://www.cadac.com/Pages/index.aspx
Message 9 of 9
Hi Arjan
I need you to send me a email with your name and company name, so I can send the neseccearly contact information.
Send the email to me.
dag.austrheim(at)autodesk.com
”Boost
