AutoCAD Plant 3D General DIscussion
Member
provencecn
Message 1 of 7 (1,393 Views)
ISO symbol
1393 Views, 6 Replies
09-15-2011 11:36 PM
It is about lined pipe.  SKEY=FPFL,TYPE=PIPE-FIXED
When use AutoCAD Plant 3D 2011 version it is okay to generate isometric, but fails in using 2012.By the way I know how to make ISO symbols for pipe fittings such as sight glass. Should I change something during making the block for lined pipe or is it a different way?
Employee
PeterQuinn
Message 2 of 7 (1,374 Views)
Re: ISO symbol
09-16-2011 02:09 PM in reply to: provencecn
If you have a line that will generate an iso in 2011 but not in 2012, please export a PCF file and post it here.
My guess is that you are using a SKEY that's not in the out of the box software.
Peter Quinn
Senior Product Manager
Valued Mentor
ybogdanov
Message 3 of 7 (1,370 Views)
Re: ISO symbol
09-16-2011 03:14 PM in reply to: provencecn
In Plant3D 2012 the FPFL skey don't exist like default symbol. That's why you need to create new symbol and than modify "IsoSkeyAcadBlockMap.xml" file to mapping it to the skey what you want.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Member
provencecn
Message 4 of 7 (1,347 Views)
Re: ISO symbol
09-18-2011 06:51 PM in reply to: PeterQuinn
I use Resistoflex spec which downloaded from your official website.  The first file was using 2011.The second and the third one was using 2012. I made a new symbol and modified IsoSkeyAcadBlockMap.xml but the second one is still not right. I want it like the normal pipe with flanges.
Employee
VickyADSK
Message 5 of 7 (1,276 Views)
Re: ISO symbol
09-22-2011 02:14 AM in reply to: provencecn
Please refer to below link. the correct steps for create new symbols with cutomized SKEY.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/P3D-2012-ISO-setting-problems/m-p/3151676#M3248
Vicky
Autodesk Plant Solutions
FourWideJK
Message 6 of 7 (860 Views)
Re: ISO symbol
08-21-2012 11:03 AM in reply to: provencecn
Did you get this figured out ? I'm haveing the same issue with 2013.
I have modified IsoSkeyAcadBlockMap.xml many times but can't get the pipe to show with flanges on the end, or the elbows. If I change the pipe to be TYPE=PIPE  then it will show the pipe as a line but otherwise its a box with a star in it.
Any help is appreciated, as I just drew all the lined pipe in the plant and now I can't get the ISOs to work.
Member
provencecn
Message 7 of 7 (850 Views)
Re: ISO symbol
08-21-2012 05:42 PM in reply to: provencecn
nope
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
