AutoCAD Plant 3D General DIscussion
Valued Contributor
Arch_art
Message 1 of 4 (402 Views)
ISO - Symbol not display correctly
402 Views, 3 Replies
08-16-2012 07:09 PM
I am trying to create a iso, in the pipework, I have placed a Nipple. Nipple is defined as
TYPE=COUPLING, SKEY=NRSC; Which make it on the iso drawing. But problem is, instead of showing the block "nipple" accordingly the IsoSkeyAcadBlockMap, it shows a block call "placeholder". Now, I don't know why it is doing this. The only thing that I can think of is the Type is not quite right. So I tried Fittings, Nipple. It doesn't even work. Is anyone knows this?
Also, where I can find the TYPE definition? Is there a list which tell you what fittings should be considered as what TYPE in Plant 3D?
I've found it frequently doesn't like the space after the comma between the type and the skey so:
TYPE=XXX, SKEY=XXXX is bad
TYPE=XXX,SKEY=XXXX is good.
Valued Contributor
Arch_art
Message 2 of 4 (397 Views)
Re: ISO - Symbol not display correctly
08-16-2012 09:37 PM in reply to: Arch_art
It display properly now. I don't know why. It seems like Plant 3D need to think a little while. Or I need to restart Plant 3D. I am not sure. Any one can confirm this?
I sitll like to have the TYPE list if any one knows this.
dave.wolfe
Message 3 of 4 (375 Views)
08-17-2012 06:21 AM in reply to: Arch_art
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Valued Contributor
Arch_art
Message 4 of 4 (343 Views)
08-19-2012 03:10 PM in reply to: dave.wolfe
Thanks, Dave
This does fix the problem I have. Interesting !
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
