AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Iso Symbol Instrument
2 REPLIES 2
IvanViqueira
2114 Views, 2 Replies
HI,
I did a FLOW METER iso symbol. Everything is correct, but I would like to add the TAG. For example: FIT - 4343.
If I use the point CP, the result is:CauCP.jpg
However, I would like to get the ISO symbol like that:caU2.jpg
Is it possible?.
Thank you for all
2 REPLIES 2
jabowabo
in reply to: IvanViqueira
IvanViqueira
in reply to: jabowabo
Thank you, jabowabo.
I tried it, but I haven't got it yet, because I created my flow meter in the catalog and it is a valve, not an instrument. It doesn't have the same properties. And I have problems when I use IsoTag.
”Boost
