AutoCAD Plant 3D General DIscussion
Active Contributor
tarrynd
Message 1 of 16 (1,608 Views)
ISO splitting
1608 Views, 15 Replies
10-01-2012 11:38 PM
Hi All
I would like to know if anyone has any more information on ISO splitting. I have a pipe and 2 smaller pipes are connected using half couplings (as seen in attached screen shot). When I generate an ISO it created 4 different ISO's instead of 1, even when I select the "Force Iso onto one sheet" option in the Advanced Iso Creation options. I did some re search and I found these 2 blogs (http://www.davetyner.com/forum/showthread.php?10029-Plant-3D-2012-Isometric-Splitting&highlight=forc... , http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Force-iso-onto-one-sheet/td-p/3275015) on this and have tried both, tested connections, i have made sure all the line numbers are correct etc and still I get the same result (4 ISO's). I hope Autodesk or anyone can give me some insight into this, or tell me if this is a bug.
Tarryn
Valued Mentor
Rich.O.3d
Message 2 of 16 (1,602 Views)
Re: ISO splitting
10-01-2012 11:41 PM in reply to: tarrynd
right click a component
add to selection all connected components
do all your parts highlight?
if not, then your iso will not be connected
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Active Contributor
tarrynd
Message 3 of 16 (1,597 Views)
Re: ISO splitting
10-01-2012 11:48 PM in reply to: Rich.O.3d
Hi There
Thanks for the reply.
This is one of the 1st things I checked, everything is connected. The ISO generates perfectly when I change the half coupling to stub in's. The end types for my Half coupling are 1=THDF; 2=BV, not sure if this has anything to do with it.
Tarryn
New Member
carnie
Message 4 of 16 (1,576 Views)
Re: ISO splitting
10-02-2012 01:53 AM in reply to: tarrynd
Hi Tarryn, is it possible that you have toggled the iso property changes, under the Iso Creation Options? Here you can force a iso split according material, spec or line No changes. Also the DWG congestion slider where is that set to? Just a couple of suggestions, i hope they help.
Active Contributor
tarrynd
Message 5 of 16 (1,572 Views)
Re: ISO splitting
10-02-2012 02:01 AM in reply to: carnie
Hi
Thank you for the reply and suggestions. The "Spilt Iso when property changes" option has never been ticked, I normally check the "Force Iso onto one sheet" option however. Also I have tested both sliding the "drawing congestion splitting" option to the highest as well as the lowest and tried producing ISO's both ways, neither make a difference. I mentioned that if I change the half coupling to a stub in, then the Iso is produced correctly, the minute it is half couplings (which is what I need) it splits into 4 Iso's at the couplings. I have checked all is connected and they are... I am not sure what else I could possibly try...
Valued Mentor
Rich.O.3d
Message 6 of 16 (1,541 Views)
Re: ISO splitting
10-02-2012 03:31 PM in reply to: tarrynd
did you make the half couple or get it from an existing catalogue
I remember having an issue with them when i made them...i think i ended up copying an olet and making my own
CAD Management 101:
Active Contributor
tarrynd
Message 7 of 16 (1,530 Views)
Re: ISO splitting
10-02-2012 10:17 PM in reply to: Rich.O.3d
The Half coupling was actually brought through from the AutoPlant Specs.
Thank you. I am have also contacted ask the expert, Jarrod Mudford, and he has provided me with the same solution, I will test this out on my side today and report back on my results.
Valued Mentor
Rich.O.3d
Message 8 of 16 (1,524 Views)
Re: ISO splitting
10-02-2012 11:08 PM in reply to: tarrynd
ahhh..Muddies on the case......he will get you sorted
CAD Management 101:
New Member
tht7763
Message 9 of 16 (1,171 Views)
Re: ISO splitting
01-01-2013 06:40 PM in reply to: tarrynd
Hi tarrynd,
I have exactly same problem splitted drawings with half couplings.
Could you pls report back your solution?
Is it solved by making up an olet?
many thanks!
Active Contributor
tarrynd
Message 10 of 16 (1,080 Views)
Re: ISO splitting
01-13-2013 10:56 PM in reply to: tarrynd
Hi There
Yes creating my Half couplings as OLETS sorted out my problems. It was a bit of a long way around because instead of creating a half coupling in my spec with only the size on my half coupling i had to create mutiple olets because with olets you need to specify both of the connecting components sizes. So for my 25mm Half coupling, I had to create 25x50, 25x65, 25x80, 25x100, etc etc olets. But in the end they work well and my ISO's are pulled correctly.
hope this helps.
Kind regards,
Tarryn
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
