I saw talk of inserting an large Iso sheet so when you create the iso's it will go on one drawing. Anyone know how and where to insert the sheet? I also may need a large iso sheet you someone has one. Trying to get the iso to fit on one sheet. It's killing me.. 🙂
Right click on the Project in Project Manager then select Properties.
Scroll down on the left hand pane to "Isometric DWG Settings" and expand it. At the bottom of the list is "Title Block" and here is where you define the .dwt file for the Title Block. The defaults are A2 and A3. Change the .dwt file or edit the current one.
I changed the sheet size to 22X34 and the draw area. I also select force to one sheet and slid the more bar. It is still making the same amount of sheets. Now that means #1 piece ids not the same as the #1 piece on the other sheet. I need it all to go on one sheet. That would make my life a lot easier.
Hi Bob,
See question #18 on the current expert page.
http://autocad.autodesk.com/?nd=plant_ask_the_expert
I did everything #18 answer said. Also i created a large sheet 22"x34" and still it creates a small iso on 5 sheets. one sheet one flange..etc. I do have the same tag number assigned the the spool.
