AutoCAD Plant 3D Forum
ISO PROBLEMS
4 REPLIES 4
752 Views, 4 Replies
ISO PROBLEMS
If I choose to generate a Quick ISO and select all the components in the pipe an Iso is generated but is split at every singel item/weld! Is there and Isogen switch to controll this? My pipes does not have any disconnect markers.
4 REPLIES 4
when using 'quick' ISO's, you need to select the items all in one pick...either with a crossing window or a selection window...or you can pre select all the items you want by picking individually (or using the append to selection 'between' tool), then when the quick iso asks for selection just hit L for last.
Maybe you should try click on the pipe, then append by all connected parts then tag that line, and use the production iso method. Hope this works. Cheers
This also could be due to the length or number of components in the pipeline.
ISOgen will automatically break the pipe if there is too much on one page.
Stassel.
please read my post....it answers this question exactly...no need to try clicking on anything, no its not due to the number or length...its purely a result of the selection method that was used.
”Boost
