AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISO PROBLEMS - SPLIT POINT & DIM to POINT
4 REPLIES 4
MOLGRAND
698 Views, 4 Replies
I'm having a little trouble in tweaking my Isos - when using the lap joint & spin flange they tend to break for continuation at the lap joint b/w & not on the gasket face. Also they seam to want to dimension to the lap joint b/w & not to the gasket face see attached PDF example.
Any helpers?
Regards
Gary
4 REPLIES 4
Dan.Scales
in reply to: MOLGRAND
Do you have a small example project that you can provide for testing here?
Dan
Dan Scales
MOLGRAND
in reply to: Dan.Scales
Hi, See attached. I have attached one of the models from a large project, along with PDF files of the Isos I ran off & a PDF of the g/a which was print from the Otho drg produced. I hope you can help as it makes the ISO drgs difficult to work with - at the moment I have 3000 Isos! Regards Gary Randall
Dan.Scales
The drawing doesn't seem to have been uploaded.
Could you try again?
Dan
Dan Scales
MOLGRAND
Hi, Drg attached again Cheers
”Boost
