AutoCAD Plant 3D General DIscussion
Distinguished Contributor
MOLGRAND
Message 1 of 5 (452 Views)
ISO PROBLEMS - SPLIT POINT & DIM to POINT
452 Views, 4 Replies
09-01-2012 01:18 PM
I'm having a little trouble in tweaking my Isos - when using the lap joint & spin flange they tend to break for continuation at the lap joint b/w & not on the gasket face. Also they seam to want to dimension to the lap joint b/w & not to the gasket face see attached PDF example.
Any helpers?
Regards
Gary
Product Support
Dan.Scales
Message 2 of 5 (368 Views)
Re: ISO PROBLEMS - SPLIT POINT & DIM to POINT
10-04-2012 09:53 AM in reply to: MOLGRAND
Do you have a small example project that you can provide for testing here?
Dan
Dan Scales
MOLGRAND
Message 3 of 5 (364 Views)
Fwd: ISO PROBLEMS - SPLIT POINT - 1 of 2
10-04-2012 10:56 AM in reply to: Dan.Scales
Hi, See attached. I have attached one of the models from a large project, along with PDF files of the Isos I ran off & a PDF of the g/a which was print from the Otho drg produced. I hope you can help as it makes the ISO drgs difficult to work with - at the moment I have 3000 Isos! Regards Gary Randall
Product Support
Dan.Scales
Message 4 of 5 (351 Views)
10-05-2012 06:21 AM in reply to: MOLGRAND
The drawing doesn't seem to have been uploaded.
Could you try again?
Dan
Dan Scales
MOLGRAND
Message 5 of 5 (348 Views)
10-05-2012 07:25 AM in reply to: Dan.Scales
Hi, Drg attached again Cheers
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
