AutoCAD Plant 3D Forum
ISO generation has symbols on top of each other
3 REPLIES 3
dennis
386 Views, 3 Replies
What are the basic things I should check when an ISO generates a layout but has symbols on top of each other?
3 REPLIES 3
quentin.contreras
in reply to: dennis
What sheet size are you using? Have you tried to setup a larger (24"x32") sheet? If you have a complex pipe run you might have to use a larger sheet size.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
quentin.contreras
in reply to: dennis
Were you able to resolve the issue?
Quentin Contreras
dennis
in reply to: quentin.contreras
We had to go to a D-Size to get it to look right.  B-Size just wouldn't work.
”Boost
