I get the following message from Iso creation:
Iso Creation start time : 2013-09-11 14:33:09
Iso Creation finish time: 2013-09-11 14:43:18
Duration : 00:10:09
Output folder : X:\Projekt\2009-2012 Projekt\31201263-Vaxjo-Energi-2012\VEAB Sandvik -2 och -3 2013\Isometric\TecNet_A2\ProdIsos\Drawings
2 Isometric(s) successfully created with no error conditions:
X:\Projekt\2009-2012 Projekt\31201263-Vaxjo-Energi-2012\VEAB Sandvik -2 och -3 2013\Isometric\TecNet_A2\PCFs\3-LGB45-BR010.pcf
X:\Projekt\2009-2012 Projekt\31201263-Vaxjo-Energi-2012\VEAB Sandvik -2 och -3 2013\Isometric\TecNet_A2\PCFs\3-LGB46-BR010.pcf
1 Isometric(s) were not able to be created:
X:\Projekt\2009-2012 Projekt\31201263-Vaxjo-Energi-2012\VEAB Sandvik -2 och -3 2013\Isometric\TecNet_A2\PCFs\3-LGB45-BR020.pcf
INFO - Loading input: 'X:\Projekt\2009-2012 Projekt\31201263-Vaxjo-Energi-2012\VEAB Sandvik -2 och -3 2013\Isometric\TecNet_A2\PCFs\3-LGB45-BR010.pcf'
INFO - Loaded '1' model(s).
INFO - Processing: '3-LGB45-BR010'.
WARNING - No break points have been specified.
INFO - Model-split has been skipped.
INFO - Generated drawing: 'X:\Projekt\2009-2012 Projekt\31201263-Vaxjo-Energi-2012\VEAB Sandvik -2 och -3 2013\Isometric\TecNet_A2\ProdIsos\Drawings\3-LGB45-BR010.dwg'.
WARNING - No tables are configured to be exported.
Ett fel inträffade under läsning från pipe. Denna pipe har avslutats. (109, 0x6d).INFO - Loading input: 'X:\Projekt\2009-2012 Projekt\31201263-Vaxjo-Energi-2012\VEAB Sandvik -2 och -3 2013\Isometric\TecNet_A2\PCFs\3-LGB46-BR010.pcf'
INFO - Processing: '3-LGB46-BR010'.
INFO - Generated drawing: 'X:\Projekt\2009-2012 Projekt\31201263-Vaxjo-Energi-2012\VEAB Sandvik -2 och -3 2013\Isometric\TecNet_A2\ProdIsos\Drawings\3-LGB46-BR010.dwg'.
What shall I do to fix that line 3-LGB45-BR020.
