AutoCAD Plant 3D Forum
Iso generation failure
5 REPLIES 5
strnadje
1241 Views, 5 Replies
When I get an Isometric failure I don't see anything that tells me where the iso line failed. Other than replacing all the components in the line is there another solution to locating the error?
5 REPLIES 5
Venkatesan.A
in reply to: strnadje
You can find the error details in the log file that is created during iso generation.
This log file can be found in the lower left corner of your "Isometric creation result" window (refer attached image).
You can also locate this log file in your **\project directory \Isometric\style (check_A2 etc)\ISOCreationLog.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
strnadje
in reply to: Venkatesan.A
I found the log file and all it told me was:
FAILURE - Sequence contains no elements
What does that mean?
Thanks for your first response.
Venkatesan.A
Could you post your PCF here?
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
strnadje
We will resolve this issue directly with Autodesk.
Dinant
How can i solve the error:
There was an error reading from the pipe: Unrecognized error 109 (0x6d).
It looks to me that the system can't read the information from the pipeline but where should i look?
”Boost
