AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Iso generation connected to dwg missing and broken down to many sheets
1 REPLY 1
eadkins73
401 Views, 1 Reply
We are having two issues:
1 - when we run isos the end points connected to other sheets are missing the "connected to dwg...". How do I fix this?
2 - we will get an iso broken up too much and will end up with just an elbow on one sheet and then a valve on the next and then the rest of the pipeline. Why is it doing this?
We are using 2014
Ed
Ed Adkins
EA2 Engineering
www.ea2eng.com
1 REPLY 1
Attila.Vallyon
in reply to: eadkins73
1.
Check the project settings:
Isometric dwg settings/annotation/
if the "show end connect annotation on iso" is checked
2.
Well,
the most important thing is how you built the model up. If there is a break in the line, than there will be a break in the ISO as well, and it will be an extra sheet.
You can check the center line continuity by clicking on an item in the line and see the red centerline. If there is a break you have to correct it.
As well you can check this thread:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Force-iso-onto-one-sheet/m-p/3275015/highlight/true#M...
Attila Vallyon
”Boost
