AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Iso Elevation unit
5 REPLIES 5
Arch_art
2155 Views, 5 Replies
Iso Elevation unit
My current drawing is done in mm, including Z. When I create iso drawings, is there anyway we can display the Elevation in meter instead of mm? What can do to change the settings?
I am working with Plant 3D 2012.
Tags (3)
5 REPLIES 5
neonade
in reply to: Arch_art
You could try to changing the style name"Metric" change to precision2 and use the scale of 0.001.
See if it works but i am using plant 3d 2013 but I think they are the same setting.
<Style Name="Metric" UnitFormat="Decimal" Precision="Precision2" Prefix="" Suffix="" Scale="0.001" Decimal="." />
Arch_art
in reply to: neonade
Thanks.. It works
Cheers
Arch_art
Is there a way when you showing the coordinate in Iso, only shown the Elevation, but not Easting, Northing? is this possible?
neonade
I think thats not possible because the setting that I know controls all the shown coordinates on the isometric drawing.
Arch_art
Thanks for reply... That's what I think it is. I just couldn't find any "Component Property" that is just given elevation. This is one of the grey area. How can I find these Component Property definition? Is there a list?
”Boost
