AutoCAD Plant 3D General DIscussion
Valued Contributor
Arch_art
Message 1 of 6 (792 Views)
Iso Elevation unit
792 Views, 5 Replies
08-14-2012 06:29 PM
My current drawing is done in mm, including Z. When I create iso drawings, is there anyway we can display the Elevation in meter instead of mm? What can do to change the settings?
I am working with Plant 3D 2012.
You could try to changing the style name"Metric" change to precision2 and use the scale of 0.001.
See if it works but i am using plant 3d 2013 but I think they are the same setting.
<Style Name="Metric" UnitFormat="Decimal" Precision="Precision2" Prefix="" Suffix="" Scale="0.001" Decimal="." />
Valued Contributor
neonade
Message 2 of 6 (788 Views)
Re: Iso Elevation unit
08-14-2012 07:04 PM in reply to: Arch_art
Valued Contributor
Arch_art
Message 3 of 6 (781 Views)
08-14-2012 08:37 PM in reply to: neonade
Thanks.. It works
Cheers
Valued Contributor
Arch_art
Message 4 of 6 (756 Views)
08-15-2012 06:07 AM in reply to: neonade
Is there a way when you showing the coordinate in Iso, only shown the Elevation, but not Easting, Northing? is this possible?
Valued Contributor
neonade
Message 5 of 6 (733 Views)
08-15-2012 07:27 PM in reply to: Arch_art
I think thats not possible because the setting that I know controls all the shown coordinates on the isometric drawing.
Valued Contributor
Arch_art
Message 6 of 6 (677 Views)
08-19-2012 07:16 PM in reply to: neonade
Thanks for reply... That's what I think it is. I just couldn't find any "Component Property" that is just given elevation. This is one of the grey area. How can I find these Component Property definition? Is there a list?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
