My current drawing is done in mm, including Z. When I create iso drawings, is there anyway we can display the Elevation in meter instead of mm? What can do to change the settings?
I am working with Plant 3D 2012.
Solved by neonade. Go to Solution.
You could try to changing the style name"Metric" change to precision2 and use the scale of 0.001.
See if it works but i am using plant 3d 2013 but I think they are the same setting.
<Style Name="Metric" UnitFormat="Decimal" Precision="Precision2" Prefix="" Suffix="" Scale="0.001" Decimal="." />
Is there a way when you showing the coordinate in Iso, only shown the Elevation, but not Easting, Northing? is this possible?
I think thats not possible because the setting that I know controls all the shown coordinates on the isometric drawing.
Thanks for reply... That's what I think it is. I just couldn't find any "Component Property" that is just given elevation. This is one of the grey area. How can I find these Component Property definition? Is there a list?
