AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISO drawing naming
3 REPLIES 3
yama21250
3936 Views, 3 Replies
ISO drawing naming
I can deal with the file naming the way it is, but I am wondering if I can change the drawing name in the title block. It is currently filling it in as our line number (size-service-spec-pidnumber-linenumber... or.... 6-MS-C1-40-001) and then if there is more than one sheet it puts an extra -1 after. I know we can change it to letters at the end but that doesn't solve the issue either. What we are used to seeing (from our previous program) is that if we have multiple sheets, they all have just the line number without anything at the end. Our "continued on" annotations would just say go to "sht 2" for continuation.
Can anyone help me accomplish this?
Thanks!
3 REPLIES 3
When multiple isometric drawings are created each drawing has the, -1 -2 -3.... added because the drawing files have to have unique names. One thing that you can try is to edit the isometric title block you are using. Then you can edit the mapped title block attributes. Look for the block attribute called DWGNAME and then the Plant 3D attributes for Drawing Name to Line Number Tag. Close out of the project setup and accept all save changes you made. Then try to run your isometrics again.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
yama21250
in reply to: yama21250
Thanks, that gets me half way there. Now is there a way to change the CONT'D ON to say just the sheet number and not the whole line number? I have attached an image that might explain better.
Is there any way to do what I described in my subsequent post?
”Boost
