Hello!
I tried to create an isometric from a pipeline and got an error message "errors were encountered". Error log and picture of the pipeline are attached. What could I have done wrong? I have managed to successfully create isos from other pipelines in the same project.There are no disconnections in the pipeline, everything should be OK.
The pipeline is the yellow one in the picture.
Jörgen
Yes, here it is. Program didn't name it by the line number, but named it UserDefinedLine.pcf for some reason.
Here is the download link for PCF file: http://www.speedyshare.com/file/cgaW2/UserDefinedLine.pcf
Jörgen
Hi Jörgen,
I was able to generate isos successfully for Check, Final and Stress. Any chance you can attach the IsoConfig.xml and the Iso.dwt for which the iso creation for this pcf is failing.
Karthik
I think Jorgen and I are in the same boat.
I ran t he ISO creation before and it worked, but now I get the " Errors were encountered" message.
Can you help me out with this problem please? I appreciate your assistance.
Patrick
