AutoCAD Plant 3D General DIscussion
Valued Contributor
Jorgen1990
Message 1 of 7 (680 Views)
ISO creation error
680 Views, 6 Replies
01-27-2012 08:37 AM
Hello!
I tried to create an isometric from a pipeline and got an error message "errors were encountered". Error log and picture of the pipeline are attached. What could I have done wrong? I have managed to successfully create isos from other pipelines in the same project.There are no disconnections in the pipeline, everything should be OK.
The pipeline is the yellow one in the picture.
Jörgen
Employee
Adsk_amitb
Message 2 of 7 (641 Views)
Re: ISO creation error
01-29-2012 08:58 PM in reply to: Jorgen1990
Can you provide the PCF please?
Valued Contributor
Jorgen1990
Message 3 of 7 (611 Views)
02-01-2012 12:17 AM in reply to: Adsk_amitb
Yes, here it is. Program didn't name it by the line number, but named it UserDefinedLine.pcf for some reason.
Here is the download link for PCF file: http://www.speedyshare.com/file/cgaW2/UserDefinedLine.pcf
Jörgen
Employee
karthik.nathan
Message 4 of 7 (576 Views)
02-07-2012 08:17 PM in reply to: Jorgen1990
Hi Jörgen,
I was able to generate isos successfully for Check, Final and Stress. Any chance you can attach the IsoConfig.xml and the Iso.dwt for which the iso creation for this pcf is failing.
Karthik
New Member
MOMENTUM2
Message 5 of 7 (478 Views)
09-11-2012 12:12 PM in reply to: Jorgen1990
I think Jorgen and I are in the same boat.
I ran t he ISO creation before and it worked, but now I get the " Errors were encountered" message.
Can you help me out with this problem please? I appreciate your assistance.
Patrick
Distinguished Contributor
Arun_Kumar_K
Message 6 of 7 (457 Views)
09-14-2012 08:44 AM in reply to: Jorgen1990
please do the following, its only a temporary work flow. Copy isoconfig file from other isostyle folder and paste in your required isostyle folder.
Arun_Kumar_K
Message 7 of 7 (453 Views)
09-14-2012 08:48 AM in reply to: Arun_Kumar_K
Make sure you keep a backup of your present isoconfig file.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
